If anyone is looking for a cheap telescoping chop saw Aldi have one in their special buys section.
Features
  • Integrated laser beam for precision
  • Ideal for cutting wood-derived products
  • Quick lock system
  • 2 Speeds max. 3200rpm/5000rpm
  • Highest position blade diameter: 21.6cm
  • Mitre capacity: 45° left - 45° right
  • Cross cut at 90°: 340 x 65mm
  • Mitre cut at 45°: 240 x 65mm
  • Compound cut at 45°: 240 x 38mm
  • Max. speed in rpm (2 speeds): 3200rpm / 5000 rpm min-1
  • Bevel Type: 45° left / 0
here
  • 2 weeks later...
After a little UPS snafu the saw and stand have arrived.
The saw is a rebadged Scheppach HM80MP. Comes with a 40 TPI multi material blade installed.
Out of the box the bevel adjust lock stops required adjustment and the laser alignment required adjusting.
The dual slides for the saw feel nice and smooth, no free play in them.
I've done a few test cuts and it seems good enough for what I need it to do.
