External bifold standard sizing?
Matt540
At the final design stages of my build and just going over the small details. The architect has a 4.25m bifold to the garden and in the spirit of trying to help my budget as much as possible I’m trying to make sure I have a standard size opening.
from what I’ve seen 4.2 is available along with 4m. With 4m being a bit cheaper naturally.
Any thoughts or expertise on standard sizes?
thanks
matt
Odd number of panes is a good idea as you will have a "normally" opening master door at one end, a good idea if you plan on using it regularly as an access/egress door.
Leafs are normally 700-1000mm each. So for a 4200 opening you could have 5 840mm leafs. Either that or 4 as above would be smashing.
We've a 5 leaf, 4620mm door arriving in two weeks time!!!!
