Archer Posted December 2, 2024 Posted December 2, 2024 On 01/12/2024 at 15:43, gravelld said: Really interesting thread. We're looking at a renovation project at the moment with a late 70s forced air heating system. First priority would be upgrading the building fabric (and likely removing a lot of asbestos). But after that, it would be interesting to use the existing ducting. If we achieve good levels of airtightness, would it be possible to use an exhaust air heat pump to also combine ventilation? Good luck with it all however you decide to progress. Our house is also 70's and we ended up keeping the ground floor steel ducts and adding a second zone in with new ducting and vents from the ceiling in the first floor. Obviously with heat pumps the supply temperature is much lower than gas warm air so you need to run the system for longer essentially to achieve the same input of heat. Most of the time this is beneficial because you can get the same level of comfort at a lower set air temp when the system is running. Ours feels a tiny bit underpowered when it's really cold. It still gets up to temperature but it takes hours to do so. Only seem to notice this at freezing and below, I think because of the heat pump defrost cycles and generally greater heat loss ( our house isn't that well insulated) I'm still not entirely sure how we got it wrong. The A2A heat pump itself is oversized so should be fine. My suspicion is that the 2 indoor air handlers are too small because the upstairs duct work is custom made so unlikely to be the problem. Either way, it's a bit annoying but otherwise the retrofit has worked fine. Much better than the 70's original gas system we replaced. 1
robin coles Posted December 25, 2024 Posted December 25, 2024 On 08/12/2023 at 06:12, Gooman said: PS - If I was going to try and persuade them that the UK is a worthwhile market, does anyone have any stats on how many domestic warm air heating systems are in use in the UK? https://ecohappy.co.uk/heating/types-of-central-heating-systems/ "Historically, warm-air heating systems were prevalent in UK dwellings. Approximately 0.5% of dwellings still have a warm air heating system, but they only have a lifespan of up to 20 years. Finding spare parts is becoming increasingly difficult as they are rare and therefore more expensive." Not sure about the "up to 20 years lifespan". Our house, including the ducting and Creda Electricaire, was built in 1965. Still going strong. Replaced the fan motor about 9 years ago but that is it. Though I would love to know how to replace it and with what I do wonder which system will do another 59 years! Closest I've got is this system from France (mentioned in more detail previously in this thread) https://www.aldesgroup.com/en/our-expertise/thermal-comfort
Gooman Posted January 2, 2025 Author Posted January 2, 2025 On 25/12/2024 at 00:13, robin coles said: Though I would love to know how to replace it and with what I do wonder which system will do another 59 years! Closest I've got is this system from France (mentioned in more detail previously in this thread) https://www.aldesgroup.com/en/our-expertise/thermal-comfort Johnson & Starley are rumoured to be planning an air-to-water heat pump system with a warm air heat interface. That would be a direct replacement for most J&S units (and maybe others if the ductwork is compatible). Plus, as it's air-to-water it would be eligible for a heat pump grant.
robin coles Posted January 16, 2025 Posted January 16, 2025 @Gooman thanks, will follow J&S for updates
Jeff Dee Posted September 23 Posted September 23 (edited) Any news about which Heat Pump (Water/Air) manufacturer can supply an ASHP unit that can be used with a Johnson & Starley warm air unit. Presently J&S are not making any ASHP. From Johnson and Starley: Johnson & Starley does not currently manufacture heat pumps, as there are already a wide range of ASHP manufacturers and systems available on the market. However, the J&S Aquair can be incorporated into an ASHP installation. Due to the lower flow rates typically associated with heat pump systems, the Aquair would generally need to be sized larger than would be required for a conventional heating system. Based on an existing warm-air heater, a J32, we would anticipate that an Aquair S-20 might be suitable. However, the final specification should be determined by the ASHP installer following a heat-loss calculation for the property, to ensure that the correct output is selected. Interesting to hear that, in principle, it should work providing you get the correctly rated ASHP and a slightly higher rated Aquair S warm air model - depending on your layout. Mine has very little ducting, in fact the Aquair would sit straight on the existing plenum (duct), although I suspect that some adjustment will be necessary. Also it looks like you also need to factor in extra kit like water reservoir holding tanks, to and from the ASHP. However how big they are and where they need to be installed still needs to be confirmed... Anyone else got any further yet ... Edited September 23 by Jeff Dee
