Conor Posted May 13, 2021 Posted May 13, 2021 I'd planned on setting down 25mm PIR on our intermediate floors, then UFH and then 75mm screed. PIR is now nearly double the price it was when I costed this 18months ago. Any reason I can't set down 25mm EPS and staple the UFH pipes to it instead? Is it too fragile? Not really worried about the lower U value tbh as don't expect to need the heating much. Just for clipping the pipes to. Thanks
Dudda Posted May 13, 2021 Posted May 13, 2021 No problem at all. My friends house did this recently for the same reason. If you find the clips aren't as secure just use a few more. The clips are very cheap and will still be a massive saving.
