Irish Rover Posted May 1, 2021 Share Posted May 1, 2021 Hi guys, I hope your all well? Has anyone got an accurate mortar calculator or explain to me how to calculate mortar properly? I use this one https://www.source4me.co.uk/calculate_brick_block_mortar.php but I often find it inaccurate and I'm often left with a surplus. Link to comment Share on other sites More sharing options...
Marvin Posted May 1, 2021 Share Posted May 1, 2021 16 minutes ago, Irish Rover said: Hi guys, I hope your all well? Has anyone got an accurate mortar calculator or explain to me how to calculate mortar properly? I use this one https://www.source4me.co.uk/calculate_brick_block_mortar.php but I often find it inaccurate and I'm often left with a surplus. We used to calculate when mixed on site half went in the wall, and half on the floor, not used, or stuck to the mixer, borrowed. Most likely the problem is the difference between theory and what happened to it on the day. It can be as simple as brick frogs up or down or circular holes inside bricks being more or less filled and so on. Sorry I can't be more help. Good luck Marvin 1 Link to comment Share on other sites More sharing options...
Marvin Posted May 18, 2021 Share Posted May 18, 2021 Did some yesterday where the footings were low. There goes my calcs again! Link to comment Share on other sites More sharing options...
Irish Rover Posted May 18, 2021 Author Share Posted May 18, 2021 4 minutes ago, Marvin said: Did some yesterday where the footings were low. There goes my calcs again! Hahaha cheers for the reply Marvin, much appreciated it. Most my mortar ends up on the floor or down the cavity ?? 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted May 18, 2021 Share Posted May 18, 2021 1 hour ago, Irish Rover said: Most my mortar ends up on the floor or down the cavity ICF construction is it? Link to comment Share on other sites More sharing options...
