Floor renovation/upgade
Jozsef Nagy
Good morning All!
We bought an1960's semi detached house in Stockport a year ago now.
I am already insulated the loft area with 200mm rockwool, added OSB boards, make a new cutout and installed a loft ladder.
Now we need to upgrade and insulate the ground floor.
Ground floor is a suspended timber floor with no insulation at all.
Currently there is carpet,  22mm T&G floorboards (most of them have no T&G due it was lifted up by previous owner/builder) on 2x4 joists. Under  the joists there is a 300-320mm air gap for ventillation.
Roughly 400mm distance between centre of joist.
The whole floor area (including kitchen, chimney in the middle and understairs area) is 35m² (7m deep 5m wide) The joists running along 7m front to back. I do not see any wet/dry rot when inspected in a few paces when lifted floorboards and the area under it is fully dry. No sign of wet areas or mould.
Since we moved in the floor is a bit springy, and most of thr floorboards are creaking. When we moved in, i was lifted the carpet and removed the nails from few of the 22mmx140mm floorboards and add some screws to stop creaking.
What we planning/have in mind:
-We want to insulate it. And make additional slepper walls. This is 100%
and here comes the things that would be good to do:
-Change the 2x4 joists to 2x6
-Add new floorboards to subfloor
-Upgrade the groun floo to UFH
And now here comes a all my questions:
Sleeper walls:
I made some research and as far ask I know i need to make a honeycomb structure to do not block wentillation (what is quite obvious)
How it need to be done?
I mean first make a 100-150mm  trench perpendicularly to the joists, fill it with concrete, let it harden, add DPM and then brickwork (class 2 engineering bricks)?
As there is no guarantee that the height of the brickwork will be exactly at the bottom of  the joists, what do I need to use to fill the gap between the bricks and joists?
I have another method in mind as well:
Same trench and concrete like above, but instead of brickwork use some adjustable metal joist support like in the picture?
Joists:
I think it would be beneficial to change it, bcs all of them as old as the house (i think) and I am not sure that it can handle the load of the new floor/UFH/ tiles.
Plus it will be a peace of mind that all theese joists are new ones, so i do not need to touch it for a long time.
I was make a lot of research on the internet in the last past months, and I don't get straight answers to my questions:
Is it a good idea to change the existing  2x4 joists to 2x6 and how should it be done? I mean as i know (but maybe I am wrong) where the joists attached to the wall there is a cut-out in the bricks.
Should I make a bigger hole to fit the 2x6 or reduce end of the joist with 2 inches in the deph of the hole in the wall and strengthen the joist after the cut?
(See pic#1)
Or just replace with the original size?
Or it is a wasted time and money and just leave it as it is if there is no dry or wet rot on it
Insulation:
Which insulation is more beneficial? 100mm PIR, earthwool or sheepwool?
I am thinking on PIR or Sheepwool. But there is a lot of different application processes on the internet.  Everyone say different how it need to be done.
Some of them says a windproof breath membrane MUST be added first and then the PIR or sheepwool insulation. (See PIC)
The others says that will make the joist rot on the surface it is covered with it.
Others sas the membrane should attached straight under the joists.
Others say not any type of membrane needed. Just insulation and floor boards.
With the PIR should I need to apply expanding foam between the wall and the insulation. Or (as few of them says) MUST leave 10-15mm gap between the insulation and the wall? Which for my opinion makes the insulation as useful as an ashtray on a motorbike...
Do i need to cover the ground with any kind of membrane? If yes which is the one that i need to run with?
Floorboards:
Which boards to choose?
PAR 22x140, chipboard, OSB, plywood, NoMorePly?
Some of them says 22mm chipboard become like weetabix after a few years.
some of them says 18mm ply is the best and few of them say NoMorePly is the best.
And what structure is the best prior to UFH?
I have one in my mind which is:
Floorboard then pre trenched hard board for the UFH pipes, then a thin layer (1-2mm) of membrane, and the tiles/hardwood floor on the top.
In this case how thick the different type of floor boards need to be?
Or it is much more better and efficient to install the aluminium plate for the pipes onto the insulation and then ue the floor boards and tiles/hardwood floor?
A few details to get a bigger picture:
I can not stand that the floor is moving under us as we walking on it and all the contents of the cupboards moving like glassware, flowers pictures etc...
The other thing is that if we will have UFH, we would like to have tiles on it. And if the floor is moving I think all of you can imagine the comsequence....
The main thing is that when it will be all done, I don't want/ I can't lift tiles, UFH, floorboard to change/repair insulation/joists/floor boards.
But I guess you all think the same.
currently have a carpet which we would like to change to tiles or hardwood floor. We still not deceided yet.
3 of us (my wife, our 3 yrs old daughter and myself)  living in the house and there is no option for us to move out while the work carried out. I know it will be kind of a pain this way, but this is the only option we have.
I would like to do DIY because this way I can save £1200-£1500 on labour only to make the sleeper walls, and/or replace bad/all joists...
And i really like to DIY as much as I can.
I am already made big built in upboards, decking with roof on it, isulate the loft and boarded, insulate and reroof garage, etc...
And i am keen for woodwirking/woodturning.
Because of that I am feling quite confident to do it :)
I am plannimg to do it in around 2 weeks excluding the heating. Until the UFH i will put the carpet back temporarily. I think this is doable.
Any advice, comment or help is greatly appriciated. And please feel free to correct me if you think something above i wrong.
And as I am living here only 10 yrs ago also let me to apologise for any grammar mistakes that I made above.
Thank You in advance!
Joe
