An alternative shutter approach is to use some short lengths of narrow rebar, some wire and some OSB3 strip (about 150mm wider than gap. Pass a loop of wire through the gap and round the OSB. Secure the wire tight to the rebar on top of the planks. Do this at each end of the OSB. Then fill the created pocket with a cement ballast mix. Guess you could use timber rather than rebar if you the cut the wire later. Otherwise you can just leave the rebar in place
Edited by MortarThePoint
