1 hour ago, Russell griffiths said:
So I would look at this differently and do the lot in EPS buy it in bulk and save a fortune on PIR prices.
Sell the pir or use it in the roof.
Go to an eps manufacturer dont  buy it from a re seller, they will cut it to any thickness you want so you can tweak your finished floor height.
Interesting take on things Russell. I'll definitely enquire with the manufacturer. But as I already have the PIR on site it may be easier to just add the 200mm EPS to the set-up.
Still the questions below if anyone has opinions thanks:
100mm screed - question... can I use a self levelling liquid screed at this thickness?
150 PIR insulation (already on site)
200 mm EPS insulation
Do you think the BCO will have a problem with this? If so why?
51 minutes ago, PeterW said:
100mm EPS70 at 3 sheets to the pack for £42 inc assuming you’re not too far from Birmingham. Ecclestones are a foam converter.
https://ecclestons.com/xcart/sheet/eps70-polystyrene-sheet/polystyrene-eps70-sheet-12mm-to-300mm.html
For 225mm go with 3 layers at 75mm as it comes 4 to a pack and you will be easily sorted.
Great info thanks very much Peter.
This forum is absolutely superb. As I improve I hope to contribute where I can.
Hi guys,
Can I get your opinions on this set-up with insulation in place and DPM and DPC locations?
All good, or any glaring errors.
Thanks very much.
Edited by Johnny Jekyll
