wasimmo Posted March 27, 2021 Share Posted March 27, 2021 Hi everyone. Would appreciate some advice please. We are building a 40cm high gabion wall, which will be a step and seating area, going into garden room. We want to top the gabion with garden tiles/slabs and would like to know the best way to fix them to the gabion. Will concrete on the back of the slabs bind and fix to the gabion mesh? Do we need to place something under the gabion mesh? Any advice greatly appreciated. ? Link to comment Share on other sites More sharing options...
nod Posted March 27, 2021 Share Posted March 27, 2021 You could cut a sheet of 18 ply to size Drill it and fasten it down with wire Then tile with a flexible adhesive Probably worth squirting some foam under the ply to help it seat Link to comment Share on other sites More sharing options...
wasimmo Posted March 28, 2021 Author Share Posted March 28, 2021 On 27/03/2021 at 13:18, nod said: You could cut a sheet of 18 ply to size Drill it and fasten it down with wire Then tile with a flexible adhesive Probably worth squirting some foam under the ply to help it seat Thanks so much. Will give that a go. ? Link to comment Share on other sites More sharing options...
