phatboy Posted May 27, 2024 Posted May 27, 2024 On 27/05/2024 at 00:52, Iceverge said: Any pics of these L brackets? Why not just fix the 4x2s directly to the wall? Expand They are just standard 100x50mm 2mm thick L brackets. No pics, I fitted everything within a day so was going quick! To fit them directly would have needed at least 150mm concrete screws, and quite a few of them.
phatboy Posted May 27, 2024 Posted May 27, 2024 On 27/05/2024 at 05:22, LiamJones said: I wonder if you could have gone standard PIR in this kind of buildup, rather than the more expensive k5? What even is the difference? Expand Maybe, as it doesn't have foil and is covered with a house wrap I suppose it can 'breathe', if that's important. When I ran out of K5, I did use half a board of foil covered board, though.
