daiking Posted March 30, 2021 Posted March 30, 2021 On 16/03/2021 at 12:54, Toppers said: My decking will be raised off the floor around 250mm, I did ideally want a composite sub-frame as well but these seem to need to be laid directly onto a solid surface, are there any other compatible sub-frames I could use? My other consideration is timber finished on the top edge with a waterproof tape. What size timber would be best for the joists? I’ve seen aluminium joists but unsure of how to adequately frame it. Probably going to stick to timber with lashings of blackjack bitumen paint for a ground level deck.
daiking Posted March 30, 2021 Posted March 30, 2021 Just had 45sq m of generic composite decking delivered £40/m2 including fixing clips. Planned the deck size around multiples/fractions of the 3.6m board lengths. Joints will be fine if joists are doubled up so lots of planning to minimise extra work. Still no tidy edge feature. The proper bullnose board seems out of stock everywhere.
Toppers Posted March 31, 2021 Author Posted March 31, 2021 On 30/03/2021 at 10:25, daiking said: Just had 45sq m of generic composite decking delivered £40/m2 including fixing clips. Planned the deck size around multiples/fractions of the 3.6m board lengths. Joints will be fine if joists are doubled up so lots of planning to minimise extra work. Still no tidy edge feature. The proper bullnose board seems out of stock everywhere. I'm using Eva-Last decking, they sell a board that's grooved on only one edge to use round the perimeter, the other boards are fixed with clips but I'm not sure how you fix the last board as yet ?
daiking Posted March 31, 2021 Posted March 31, 2021 (edited) 7 minutes ago, Toppers said: I'm using Eva-Last decking, they sell a board that's grooved on only one edge to use round the perimeter, the other boards are fixed with clips but I'm not sure how you fix the last board as yet ? The ones I’ve seen like that have a hidden slot and a particular hidden edge fixing. At the moment I’m more concerned that I think I need 60 off 3.6m 6x2s which is £1050 ? from my new preferred merchant. can I use 4x2s? ? Edited March 31, 2021 by daiking
Toppers Posted March 31, 2021 Author Posted March 31, 2021 15 minutes ago, daiking said: The ones I’ve seen like that have a hidden slot and a particular hidden edge fixing. At the moment I’m more concerned that I think I need 60 off 3.6m 6x2s which is £1050 ? from my new preferred merchant. can I use 4x2s? ? I think 4 x 2's would be fine to be honest, I'm going for 400mm centres and i'll put some extra support in.
daiking Posted March 31, 2021 Posted March 31, 2021 What joist centres have people used? I’ve seen 300mm recommended for some boards but obvs 400mm would be easier - although 450mm would have been ideal for my overall sizing but that’s too far for this generic hollow decking
Toppers Posted April 6, 2021 Author Posted April 6, 2021 On 31/03/2021 at 23:06, daiking said: What joist centres have people used? I’ve seen 300mm recommended for some boards but obvs 400mm would be easier - although 450mm would have been ideal for my overall sizing but that’s too far for this generic hollow decking I've gone 400mm centres and put some cross bracing noggins in and it seems fine.
daiking Posted April 6, 2021 Posted April 6, 2021 6 hours ago, Toppers said: I've gone 400mm centres and put some cross bracing noggins in and it seems fine. Thanks. My neighbour with the same decking as me has done 400 centres. I still thinking of the easiest way to make my structure and what to support on. I have little height to play with so more digging it looks like ?
Toppers Posted April 7, 2021 Author Posted April 7, 2021 20 hours ago, daiking said: Thanks. My neighbour with the same decking as me has done 400 centres. I still thinking of the easiest way to make my structure and what to support on. I have little height to play with so more digging it looks like ? Mine is about 250mm off the ground, I concreted some posts in at the front edge to carry it then I've fixed it to the house with masonry bolts, I've also put some legs down to the ground here and there, it's solid as a rock.
