I have this sandstone:
What is the best way would you think to section it up into 4" blocks?
My plan was to use a diamond disk to scribe round it, then just use a 4" bolster and split it off like you would split concrete block.
They are to be used as a feature facing brick.
thats how i would do it
39 minutes ago, Carrerahill said:
Do you think I need to score the base? Issue is, I cannot really move it to score the bottom...
Nope, if you can score 3 sides, sharp bolster hits (not hard enough to break it) to the 3 sides and then crack it and it will break pretty cleanly
I will have a go at the weekend. Thanks.
