3 hours ago, Evs said:
Yes that is a good point if I was to get one made myself.
One company supply a cnc machined template with the purchase that you mount to the wall so that when you install it, you drill every hole perfectly and every tread goes in the exact position its supposed to.
Never going to happen.  Compared to a wall string, a template will be far worse.  Why mount a template on the wall drill holes, and fix treads individually when you can just mount a wall string and job done?
I’m not arguing it will, I’m just saying that’s what the one supplier offers with theirs. Probably because its a way of getting cost down due to a lot less material. I totally agree that a string would be the better option.
