Packman Posted February 19, 2021 Share Posted February 19, 2021 I’m renovating an uninsulated 1950s detached house, with a normal cavity masonry buildup of 100mm facing brick 50mm empty cavity 100mm block sand/cement plaster paint I was originally planning to fill the cavity with graphite eps beads and then externally insulate with 100mm graphite eps then finish with brick slips on ground floor and render on upper. However the current external brickwork is actually very good, and from a cost saving exercise i’m considering IWI instead so that I don’t need to touch the outside. I know that EWI is going to be better performance, but if I ruled this out and went down the internal route, I have a few questions: 1. Is insulated plasterboard any good? 2. If using IWI or insulated plasterboard, should I still fill the cavity or should I leave it empty to stop potential moisture / damp / mould problems? 3. How / where do I create the air tight layer in this build up? On top of the IWI/ insulated plasterboard or between the IWI/board and the blocks? 4. Will it still be possible to get an ok u-value (under 0.2) from my walls without losing any more than max 100mm internally? 5. should I go on top of the existing sand/cement plaster, or hack it off and take it back to block first? Thanks for your help! Link to comment Share on other sites More sharing options...
tonyshouse Posted February 20, 2021 Share Posted February 20, 2021 Leave plaster on, use it as the airtightness layer. Make sure that it goes down between the joists through the floor void. fill the cavity graphite eps is breathable - insulated plasterboard is ok - no battens, no voids, no air leakage paths slight bridging at internal walls, need to window reveals, heads and sills stick or fix sheets directly to plaster, no voids or air gaps 100mm follow the insulation layer through the floor void I would add false skeiling ceilings to mitigate thermal bridge at the wall, plate insulate gable and chimney/party wall above the ceiling Link to comment Share on other sites More sharing options...
gmarshall Posted February 20, 2021 Share Posted February 20, 2021 I'm very interested in this as we are currently buying a 60s detached and so about to start something very similar. The biggest issue with insulated plasterboard as far as I am concerned is the cost compared to buying the same materials seperately. It's more faff to use sepearate insulation but in my opinion worth it cost wise if DIYing. I'm planning to do that, and it gives you the option of using the foil facing of the insulation as an airtightness layer- although using the wet plaster as suggested seems very sensible if it's in good condition. Biggest challenge as said above is the detailing around joists and first floor void. Our cavities are apparently already insulated- just praying they aren't poorly filled with damp mineral wool! If you have insulated cavities at ~0.5 u value I think you will be pleasantly surprised how much internal insulation you need to get decent performance overall- I'd reccomend playing with some of the online calculators to see the different options. Link to comment Share on other sites More sharing options...
Packman Posted March 19, 2021 Author Share Posted March 19, 2021 On 20/02/2021 at 07:37, tonyshouse said: Leave plaster on, use it as the airtightness layer. Make sure that it goes down between the joists through the floor void. fill the cavity graphite eps is breathable - insulated plasterboard is ok - no battens, no voids, no air leakage paths slight bridging at internal walls, need to window reveals, heads and sills stick or fix sheets directly to plaster, no voids or air gaps 100mm follow the insulation layer through the floor void I would add false skeiling ceilings to mitigate thermal bridge at the wall, plate insulate gable and chimney/party wall above the ceiling Thanks Tony. Thats really helpful. So you would fix the insulated plasterboard directly to the plaster? Not with battens and no dot and dab? What would you do re insulation in the roof space? The loft is just going to be used for typical storage, not for rooms or anything. Will probably put the MVHR unit up there though, and maybe the megaflo cylinder. We were planning on just laying normal loft floor insulation e.g. 300mm knauf, across the floor, except for one section where we plan to vault the ceiling above the master. Is that any good, or are we better off insulating in between the rafters rather than across the floor? Link to comment Share on other sites More sharing options...
tonyshouse Posted March 20, 2021 Share Posted March 20, 2021 Insulation in the loft is best across the ceiling and ventilate the loft, build an insulated box round cylinder but better to locate in the house than the loft minimising the size of your heated envelope will reduce energy use and the opportunity, which is high in a loft, for air infiltration and draughts Link to comment Share on other sites More sharing options...
Packman Posted March 20, 2021 Author Share Posted March 20, 2021 1 hour ago, tonyshouse said: Insulation in the loft is best across the ceiling and ventilate the loft, build an insulated box round cylinder but better to locate in the house than the loft minimising the size of your heated envelope will reduce energy use and the opportunity, which is high in a loft, for air infiltration and draughts Thanks. If I can find space for the cylinder in the house, what about the MVHR unit? That ok in the loft, or better in the house too? Link to comment Share on other sites More sharing options...
