Jason L Posted February 2, 2021 Posted February 2, 2021 So do the ceiling Mvhr valves where you have a timber floor and accommodation above need to be a fire rated type, it crossed my mine the other day that they should be, but when I was on the phone to BPC and asked, he said they don’t ? ta
JFDIY Posted February 2, 2021 Posted February 2, 2021 Would that be driven by the ceiling requirements of where the valve is to be fitter?, i.e. if your building regs quote 'XXmins of fire resistance' or similar then the valves must maintain that same requirement as the ceiling
Jason L Posted February 3, 2021 Author Posted February 3, 2021 9 hours ago, JFDIY said: Would that be driven by the ceiling requirements of where the valve is to be fitter?, i.e. if your building regs quote 'XXmins of fire resistance' or similar then the valves must maintain that same requirement as the ceiling so for example the ground floor ceilings need to provide half hr resistance to the first floor, they need to be fire rated type
