triangle pieces for depth gauge in plaster work
hallega
Does anyone know where to buy triangle pieces of plastic that you pin to a wall before you plaster?
In Spain these are attached to the wall and then plaster is sprayed on thick and then a large long trowel is dragged across and these plastic pieces give you the correct depth.
Would love to know if they are used here in the Uk. Got an awful lot of walls to plaster with hardwall and then finish.
Cheers
Lynn
