15 hours ago, Nickfromwales said:
I always CT1 here as the casting of porcelain is often imperfect, as is often the tile ( especially where the pan traverses a grout line and there is a distinct wobble ). Cutting through CT1 in the event of a doomsday issue is a few minutes work. CT1 Multisolve can be used to break down and remove residual product, and clean up before re-installing. Hearing a 'dry' pan grating against a tile whilst you tighten, and then do the first test arse-fit, is bloody daunting to say the least.
And the gasket should be banned from existence  !!!!!! Do not fit, it's like a bloody slip membrane and stands the pan off an extra few mm's which means more silicone on the upper rear edge of the pan.?
Have you tried BT1 yet?
EDIT: Bodger using his finger!
Edited by Onoff
