Oxbow16 Posted January 13, 2021 Share Posted January 13, 2021 Hi I'm going to be putting in a new sink and taps into a downstairs cloakroom / utility room. The sink is a reclaimed baby belfast, and I want some old taps to match. I've found some NOS pegler taps at a good price, but they have 3/4" thread. Is this ok to connect to 15mm pipe? Will the flow rate be a LOT more than 1/2" thread? Any other potential problem in using these? Many thanks Link to comment Share on other sites More sharing options...
Temp Posted January 13, 2021 Share Posted January 13, 2021 Some old taps were designed to improve flow rates on UK gravity fed systems so if you are mains pressure the flow might be too much. If you have a site supply you could jury rig up something to test them. You can fit pressure regulators to cope with this but make sure they are accessible. I've had to adjust all of ours twice in 10 years as the flow rate seems to reduce over time possibly due to scale? Otherwise they work well. A cheat would be to fit isolator valves somewhere in the pipes to make changing washers easier. These could be tweaked shut a bit if the flow was too fast. Cheaper than pressure regulators. 1 Link to comment Share on other sites More sharing options...
Oxbow16 Posted January 14, 2021 Author Share Posted January 14, 2021 That's really helpful - thank you very much. Link to comment Share on other sites More sharing options...
Oxbow16 Posted January 14, 2021 Author Share Posted January 14, 2021 I definitely like the idea of the isolator valves. I remember in an old house the toilet use to make a hell of a racket when it refilled, and it was close to the bedroom. So I turned down the valve to reduce the flow and it worked a treat. More generally, I've just been thinking about 1/2" vs 3/4". I've been told elsewhere that if the taps are fed by 15mm pipe, the flow rate wouldn't be any different anyhow. But if that's the case, then why are bath taps always the larger size? Is it because they are usually fed by larger pipes? If not, why aren't they all the same? Sorry if I'm missing something blindingly obvious! Cheers Link to comment Share on other sites More sharing options...
