Gw1743 Posted December 8, 2020 Share Posted December 8, 2020 Hi, I finally got round to investigating the dark patch in my hallway and discovered my next door neighbors have a leaking pipe that comes out of their wall into the garden. I don’t know how long it’s been leaking for as their garden is so overgrown I can’t see the pipe from mine. I can only assume the constant running water is the cause. The right side of the wall is a new extension not even 4yrs old. Is it a simple case of once the pipe is fixed (management company sorting but very slow and not keen to take responsibility) then allow the wall to dry out then repaint or do I need to do something else? (In the photos the brick wall behind the pipe is my extension) Thanks Link to comment Share on other sites More sharing options...
Mr Punter Posted December 8, 2020 Share Posted December 8, 2020 It will take a long time to dry. Yes, just get rid of the loose stuff, wipe with bleach and off you go. Link to comment Share on other sites More sharing options...
Temp Posted December 8, 2020 Share Posted December 8, 2020 A desk fan blowing on the area will help speed up the drying process but don't let it fool you. It will dry the surface quickly making you think its done but there will still be quite a bit of water hiding in the wall. I'd give it a few months before repainting. Then you might consider painting it with Zinsser Primer Sealer (@ Screwfix) before applying a regular emulsion. I'm not sure which is better, the Zinsser BIN (Shellac based) or the Zinsser 123 (water based) but Zinsser paint is darn good where there is any damp. I'm using their paint over a shower that causes water drops to form on the ceiling. Link to comment Share on other sites More sharing options...
Gw1743 Posted December 8, 2020 Author Share Posted December 8, 2020 20 minutes ago, Mr Punter said: It will take a long time to dry. Yes, just get rid of the loose stuff, wipe with bleach and off you go. Thank you. How long roughly do you reckon I should leave it to dry out? Link to comment Share on other sites More sharing options...
Mr Punter Posted December 8, 2020 Share Posted December 8, 2020 Sounds crazy but I would leave it a year. Link to comment Share on other sites More sharing options...
Gw1743 Posted December 8, 2020 Author Share Posted December 8, 2020 11 minutes ago, Temp said: A desk fan blowing on the area will help speed up the drying process but don't let it fool you. It will dry the surface quickly making you think its done but there will still be quite a bit of water hiding in the wall. I'd give it a few months before repainting. Then you might consider painting it with Zinsser Primer Sealer (@ Screwfix) before applying a regular emulsion. I'm not sure which is better, the Zinsser BIN (Shellac based) or the Zinsser 123 (water based) but Zinsser paint is darn good where there is any damp. I'm using their paint over a shower that causes water drops to form on the ceiling. Thanks, I’ll look into that paint. Link to comment Share on other sites More sharing options...
