Red Posted October 30, 2020 Share Posted October 30, 2020 hi, in the process of ordering PIR insulated plasterboard, used British Gypsum items recently and also Gtec,both seem identical visually, due to quantity required prices have varied but the Gtec ones seem to be the cheapest, any thoughts on out of the two is the better product Link to comment Share on other sites More sharing options...
Nickfromwales Posted October 30, 2020 Share Posted October 30, 2020 Order a couple of each to get started and see which is the one with the plasterboard best bonded onto the PIR. I’ve had some where the two have separated and that’s bloody annoying. Storing these perfectly flat is paramount, and again some boards have arrived with a cup in them from being stored poorly, on a knackered pallet etc, and I’ve had to store them the other way around to retrain the board to be flat. Quality of the board is one thing, but discipline of the supplier is another key consideration. 1 Link to comment Share on other sites More sharing options...
nod Posted October 30, 2020 Share Posted October 30, 2020 1 hour ago, Red said: hi, in the process of ordering PIR insulated plasterboard, used British Gypsum items recently and also Gtec,both seem identical visually, due to quantity required prices have varied but the Gtec ones seem to be the cheapest, any thoughts on out of the two is the better product We use both and also G tech metal Gypsum are better quality But do the same job Link to comment Share on other sites More sharing options...
Red Posted October 30, 2020 Author Share Posted October 30, 2020 Thanks for the replies, if anything the British Gypsum boards seem to have very slightly thicker vapour barrier but other than that are identical ,although the Gtec seem to be slightly harder on the board construction, when fixing the screws are easily pushed through the Gypsum board Link to comment Share on other sites More sharing options...
