Ive got antique brass hinges, brass threshold and a brass door knob. Can't for the life of me find anything other than chrome concealed door loop. Will take black, brass or anything other than chrome!
Does anyone know an ironmonger-ist who might stock such an item?
Here's a thought..
You can get black surface mount versions..
https://www.hunters-wholesalers.co.uk/sewosy-dln7-black-door-loop-diameter-p-93130.html
Perhaps the flexible tube is the same diameter as the concealed type? If so peehaps you could strip down and paint the ends of a steel finish concealed unit swapping over the hose from a surface mount type. I suggest this because painting the hose part yourself may not work/last.
8 hours ago, Temp said:
That'll do nicely, thanks very much.
7 hours ago, Temp said:
Hinge type but expensive..
https://accesshardware.com/product/command-access-eth4w-4-5-x-4-5-605-energy-transfer-hinge/
24v dc only.
Google electric transfer hinge.
Ingenious, though I doubt those hinges fill fit in amongst the double rebates
Nice solution, very discrete. Touch over budget though!
Thanks @Temp, top googling!
