BotusBuild Posted September 30, 2020 Posted September 30, 2020 I think my research has confused me. What type of pipes can I use in a STP leach field? Stiff or flexible pipe (see examples below), or will either do? Slotted 3m single socket stuff like this? - https://www.plastics-express.co.uk/underground-drainage/Underground-Drainage-110mm?product_id=1795 or Perforated Twinwall Drainage like this? https://www.drainagesuperstore.co.uk/product/perforated-land-drain-coil-pipe-100mm-x-100m.html
Oxbow16 Posted October 2, 2020 Posted October 2, 2020 Hi there I don't have an answer for you, well - at least not a full one. But it is a very good question and one I have been looking into as well. What I do know is that the black corrugated stuff in your second link is against building regs. It even says so on the product page: "Not suitable as a dispersal drain for septic tanks". Note also that the second link stuff says it is single wall, not twin. Why this is the case I'm not sure. I can see that the black corrugated isn't kite marked. And maybe that's all there is to it? If there's more to it, then I would love to know why it is not considered suitable. In terms of durability, I cannot see it being a problem seeing as this is what farmers use as land drainage. A farmer's field sees a lot more "action" than the average garden! So if anyone knows of other reasons why it isn't suitable, please enlighten us both :) Cheers
Oxbow16 Posted October 2, 2020 Posted October 2, 2020 What I can add is that I spoke to a few suppliers about it and their answers varied as to why black corrugated cannot be used. For example: - Because if there is a problem with the tank and more solids were getting through to the drainage field, the pipe would clog more easily. - Smooth pipe is better for even distribution across the whole drainage field. It ensures a smooth flow. - You can use black corrugated land drainage pipe. But you should also follow building reg (!).
Oxbow16 Posted October 11, 2020 Posted October 11, 2020 @BotusBuild Curios as to what you decided in the end?
