mattp22 Posted August 25, 2020 Author Posted August 25, 2020 2 hours ago, SteamyTea said: Have you actually checked the flow rate to your house and what you can realistically supply to 4 showers running at the same time? You can reduce the flow rate, 9 litres/minutes is a pretty good shower. Avoid a wood burner, they are horrible, and not as cheap as people think. not personally, but neighbouring plot has very good pressure and is higher up than me. i need to go and check actual flow rate- 6 hour round trip though consensus seems to be that boiler stove will over-complicate the plan so UVC looks like best route (unless flow rate is disastrously low!)
SteamyTea Posted August 25, 2020 Posted August 25, 2020 3 minutes ago, mattp22 said: very good pressure Pressure tells you very little about the flow rate. I can pump my bike tyre up to 120psi, and my car tyre up to 36psi. The car tyre will still have a larger volume of air in it.
A_L Posted August 25, 2020 Posted August 25, 2020 (edited) On 19/08/2020 at 15:24, mattp22 said: So do I hook up some renewable sources to lower my electricity costs and increase SAP value? How about waste water heat recovery? (WWHR). Save about 50-60% on shower water energy and get you a few SAP points. https://recoupwwhrs.co.uk/products/ - others are available. East or West PV in Oban will produce about 670kWh/yr per kWp. How about 3kWp East and West? You will never see more than 4kW instantaneously and a standard 16A/Dual MPPT would handle it. Edited August 25, 2020 by A_L
