I just realised I posted this in the wrong forum. Asking again.
We are looking at two showers for our bungalow and I've ended up with three, I forgot I'd made an automatic eBay bid on one through the night.
So, which do I keep and which one do I resell? All were between £140-£170 new/boxed off Facebook/eBay/Gumtree
The first one is a Mira Agile ERD+ Dual Outlet
 https://www.amazon.co.uk/gp/aw/d/B07RCY6CYG/ref=ya_aw_od_pi?ie=UTF8&psc=1
Second one Hansgrohe S240 Showerpipe https://www.amazon.co.uk/hansgrohe-Crometta-Showerpipe-27267000-Thermostat/dp/B01LLRHDPU
Third one Hansgrohe E240 Showerpipe https://www.amazon.co.uk/hansgrohe-Crometta-Showerpipe-27271000-Thermostat/dp/B01MG2DESU
One will be for a main bathroom and another for a guest/Airbnb ensuite. We will have an ASHP.
It would depend on what the hole patterns and fittings were for me.
I the last 2 match, then I would put that in the AirBNB room and keep the spare so a replacement is available instantly when it gets broken, without the need to delay the next guest.
Alternatively get rid of the Mira so that you can have similar fittings in both showers.
The last two don't match as such as one has a round head the other square.
For our ensuite we have ordered this one https://www.amazon.co.uk/Mira-Showers-1-1874-005-Digital-Pressure/dp/B071NH4851/ref=mp_s_a_1_3?dchild=1&keywords=mira%2Bmode%2Bhigh%2Bpressure&qid=1597310243&quartzVehicle=25-376&replacementKeywords=mode%2Bhigh%2Bpressure&sr=8-3&th=1&psc=1
It's not like all our fittings will be the same make as the taps are a mix of Roper Rhodes and Hudson Reed.
It's not like all our fittings will be the same make as the taps are a mix of Roper Rhodes and Hudson Reed so I'm more bothered about quality wise which is the most superior.
