A-Com Posted July 28, 2020 Posted July 28, 2020 Hi, i am trying to determine a method to accurately measure the depth of applied floor screed to a new build. i did not apply it, but it appears to be thin in certain spots i.e. not to the required depth.
nod Posted July 28, 2020 Posted July 28, 2020 1 hour ago, A-Com said: Hi, i am trying to determine a method to accurately measure the depth of applied floor screed to a new build. i did not apply it, but it appears to be thin in certain spots i.e. not to the required depth. If you are going for a sand and cement it should be 75 mil average 20 ton will cover 150m2 Pumped concrete will be 50 mil and metred So you will pay for what you use
JFDIY Posted July 28, 2020 Posted July 28, 2020 If it's down already then measure from whatever was declared as the datum for the floor if it's your project. Or is it somewhere you've bought already done, that is now showing a more serious issue? If not containing underfloor pipes, you could drill it and see where you break through, assuming it's over insulation it will go soft and you can gauge the point of breakthrough as the depth. Need a bit more info on the make up and what you're trying to determine I think.
