Jay fray Posted June 22, 2020 Share Posted June 22, 2020 Hi I am in the process of building a detached outbuilding built of brick and block with cavity wall construction The neighbour on one side has a burnt out disused shed still with a car in it and a lot of soil. All three of the elevations are problem free in terms of height of DPC however this side is giving me a problem. the problem is that their ground level is at the same height as my DPC If I move some of this Excess soil I can still see the concrete base for the shed and a concrete base for the shed is 150 mm Below my DPC which is perfect I don’t think that they will allow me to remove this eXcess soil therefore if I pushed it back into theOr garden how far do I need to push back so that building control are satisfied that the DPC will not be bridged Link to comment Share on other sites More sharing options...
Temp Posted June 22, 2020 Share Posted June 22, 2020 I think 45 degrees is the steepest "angle of repose" (https://en.m.wikipedia.org/wiki/Angle_of_repose ) recommended for a soil bank. Any steeper and you need some sort of retaining wall. I'd allow space for a french drain and a 45 degree bank between your wall and the boundary. If you want to make it closer perhaps look at a retaining wall using railway sleeper(s). Link to comment Share on other sites More sharing options...
