Hello All,
I'm about to pour the first part of an IFC (Nudura) extension, a small cellar. 2m square. I'm looking for help to square up the walls and hold everything in position while I pour the concrete.
Just wonder if anyone know where int he UK I can purchase (either new or secondhand) Zonts and Zuckels? or anything similar, I'm also considering acrow props and ratchet straps!
Thanks
Hire the correct props from nudura, if you can collect them you will save a fortune on delivery, you will need so few it won’t be expensive.
However if your room room is so small why not brace it with 4x2 up the walls vertically then brace from wall to wall, you will need to get it spot on as you won’t have any adjustment.
By the time you hire acrows you could hire the proper thing.
Call your our local rep he should have a site you can go and collect a few from.
Where in the country are you.
