Quick insulation question
janedevon
Hi guys, main house is now insulated and being boarded, we are onto the garage now, this is a room with a loft above the loft will have 300 mm of roll type insulation but my question is the eaves, it is a semi vaulted celing and there is a big space at an angle down to the soffits, just breatheable felt above before tiles.
so can i pack batts of insulation into the voids as long as its not touching the felt to avoid wicking.?
Or is there a better option, rafters are 600 centres so a batt fits,in well.
thanks
Many thanks ill look into them, so confusing and contradicting views all over, i need to get some insulation in there today as i think it will be easier before boarded on monday so because breathable membrane is used i still beed to allow a 50mm gap between any insulation and the membrane?
