Shadow gap and engineered timber floor??
Hi,
I've been reading previous posts about the use of shadow gaps and timber flooring and am still having trouble seeing how this is achievable if you skim the walls and then lay the flooring afterwards.
Construction is block wall with dot and dab plasterboard with Qic Type-R shadow gap profile, to finish at floor level with no skirting board, and then hopefully engineered timber flooring.
Clearly laying the flooring and then the drylining and skim would be the easiest process, but this goes against flooring manufacturer's guidelines for laying and presumably the levels of humidity would be too high?
Does anyone have any experience of constructing this detail on site to enlighten us?
Thanks.
It’s quite easily to do
Exactly the same as with a skirting
When I do a shadow gap I set the heigh with a laser and work down  Gap skirting FF
Any floor levelling needs to be done prior to setting out
Your dry liners just need to set a laser line allowing for you gap and FF Then plug and fix a tile baton
Allowing 5 mil for the bead
Once it’s all beaded and skinned you can put your floor in sure that you are working to a level perimeter That will tie in will all your doors
Ive been to jobs Costas and similar
where the floor has had to go in first and apart from the sheeting
Your stuck with what is already down
