canalsiderenovation Posted April 30, 2020 Posted April 30, 2020 Just had a thought. As we plan on having LVT gluedown flooring throughout it just occurred to me about the stairs we have in the hall (see pic) The Amtico gluedown sample we have feels quite rigid. Is this a problem? I think it's around 2.5mm with a 0.55mm wear layer for the hall. In other rooms the flooring is 2mm with a 0.55mm wear layer.
Carrerahill Posted April 30, 2020 Posted April 30, 2020 (edited) 1 hour ago, canalsiderenovation said: Just had a thought. As we plan on having LVT gluedown flooring throughout it just occurred to me about the stairs we have in the hall (see pic) The Amtico gluedown sample we have feels quite rigid. Is this a problem? I think it's around 2.5mm with a 0.55mm wear layer for the hall. In other rooms the flooring is 2mm with a 0.55mm wear layer. You are not bending it around stairs if that is what you mean. I put the 30 year warranty version down about a month ago and it wouldn't be getting bent and glued around anything. Whenever I have seen LVT on stairs it is with a nosing detail/cap. Edited April 30, 2020 by Carrerahill
canalsiderenovation Posted April 30, 2020 Author Posted April 30, 2020 Thanks, I since found the nosing caps which look fine. Cheers.
