We have 3 towel rads (Zenhder) in the three bathrooms on first floor - only rads in the house and are on their own circuit.
Two are hot, one is cold - has been like this since commissioning. Plumber suspected that it was air-locked and  came out and 'fixed' it but it didn't last.
I've tried bleeding, there is an initial release of air / water but then it slows to a trickle and then nothing.
I've tried turning other two off and running pump - it eventually heats up and releases a little bit more air when bled but as soon as the other two are opened up again it goes cold.
Have asked plumber to come back, but while I wait any suggestions on resolving this?
Thanks.
21 hours ago, PeterW said:
Is it a pressurised system..? What is the pressure set at..?
Yes, and I'd forgotten to recharge the vessel after the initial round of bleeding. It doesn't have a gauge but charging it up seemed to do the trick.
Thanks Peter!
