Onoff Posted April 13, 2020 Author Posted April 13, 2020 12 minutes ago, ProDave said: I also remember an automated star delta starter I think using 3 or 4 contactors and a timer relay to sequence them. It can make quite a bang if you get the wrong 2 contactors energised at the same time!!!! Agree I would just wire it in delta to a VSD. If you don't want to spend much there are some really cheap ones on ebay if you want to take a punt on something arriving from china or HK. Something like this maybe? https://m.banggood.com/2_2KW-220V-9_5A-1HP-To-3-Phase-Variable-Frequency-Inverter-Motor-Drive-VSD-VFD-p-1392464.html?rmmds=search
Onoff Posted April 13, 2020 Author Posted April 13, 2020 So basically everyone's guessing what it is and what motor it is. For my money it's a 2 speed double star wound motor and that switch is simply off or one of two speeds. Thinking I could stick an ohm meter on the motor and figure how its wired from interrogating the windings resistance.
Jeremy Harris Posted April 13, 2020 Posted April 13, 2020 3 minutes ago, Onoff said: So basically everyone's guessing what it is and what motor it is. For my money it's a 2 speed double star wound motor and that switch is simply off or one of two speeds. Thinking I could stick an ohm meter on the motor and figure how its wired from interrogating the windings resistance. Dead easy to just do that winding resistance check. If it's a standard motor it will have three separate windings, with the start and end of each brought out as six wires.
Onoff Posted April 13, 2020 Author Posted April 13, 2020 2 hours ago, Jeremy Harris said: Dead easy to just do that winding resistance check. If it's a standard motor it will have three separate windings, with the start and end of each brought out as six wires. He's put the motor back in and bolted it all up so I'll have to convince him to take it all out again!
PeterW Posted April 13, 2020 Posted April 13, 2020 42 minutes ago, Onoff said: He's put the motor back in and bolted it all up so I'll have to convince him to take it all out again! is that so the scrap man can collect it in one piece though ....?? My mate does machinery clearance and refurbs and they won’t buy anything older than 7-8 years now as it just doesn’t pay. They skip some stuff that they get that is 10-12 years old when it comes as part of a factory clearance as they time and cost spent working on them far outweighs any profit.
Onoff Posted April 13, 2020 Author Posted April 13, 2020 1 hour ago, PeterW said: is that so the scrap man can collect it in one piece though ....?? My mate does machinery clearance and refurbs and they won’t buy anything older than 7-8 years now as it just doesn’t pay. They skip some stuff that they get that is 10-12 years old when it comes as part of a factory clearance as they time and cost spent working on them far outweighs any profit. This will get used almost certainly.
Onoff Posted April 13, 2020 Author Posted April 13, 2020 The mill is a STEINEL but as to what model? Little STEINEL plate on the front but the actual ID plate as aforementioned is long gone. SV4 maybe? Runs OK it seems on a phase converter. Starts slow (without hitting the BOOST button) and changes between slow and fast speeds seemingly OK. Video: 1
