colin7777 Posted March 19, 2020 Posted March 19, 2020 (edited) Hi All, Sorry tried to remove but couldn't find how to do that so just taken out content. Edited March 19, 2020 by colin7777 changed
Temp Posted March 19, 2020 Posted March 19, 2020 +1 This is all info that might be needed to design the foundations. See the key top right. Seems mostly self explanatory. Sway frames need to resist lateral loads as well as vertical so you shouldn't just sit those on block walls without care. They should be bolted down to something more solid like the strip foundations. Not all Architects are comfortable designing foundations. Many/most prefer to use a Structural Engineer.
