Wagas Posted February 4, 2020 Posted February 4, 2020 Sorry if this has been asked before but the max recommended floor surface temp for LVT is 27c. But without being able to measure the surface floor temp what temp do you think I can realistically set the water to in the UFH pipes? I'm thinking the pipes take up a small percentage of the floor area plus there's 40+mm of screed so 27c water temp wont equal 27c floor surface temp. What are others doing? Does 40c water temp sound ok? Thanks
SteamyTea Posted February 4, 2020 Posted February 4, 2020 7 minutes ago, Wagas said: But without being able to measure the surface floor temp Why can't you measure the surface temperature?
SteamyTea Posted February 4, 2020 Posted February 4, 2020 3 minutes ago, Wagas said: So I should just buy an IR thermometer? Yes, they are always worth having. For a few pounds you can make a cheap data logger as well.
