Robert Clark Posted February 1, 2020 Posted February 1, 2020 Hi Guys When adding tile hanging to external brick walls that already has cavity wall insulation, is there much benefit to adding a thin layer of insulation under the tiles / battons? If so, what insulation would you suggest? Dont want to drastically increase the wall thickness Thanks
A_L Posted February 1, 2020 Posted February 1, 2020 Assuming a brick/50mm cavity/brick construction then 50mm of mineral wool batt will save about 40% and 50mm of PIR/PUR about 50% 2
