Hi,
I noticed a gap under one of the radiator pipes as if something (mice?) was pushing out the plasterboard (definately shifted in last 24 hours) and I want to seal this up. The pipe probably gets to 60oC so I want to check what's the best way to seal this damage - what materials would be safe to use and not corrode the pipe and maybe push in some steel wool for good measure? Would caulking / expanding foam be appropriate? Thanks
