New washer at rental ( the old washers door ‘magically’ ripped itself off !! Ffs )
4 transit bolts to remove . Dear God ! Designed not to be removed . Only got 1 out as it should be I.e pulled through the hole . The rest were sworn at and brute force applied !
40 minutes ago, MikeGrahamT21 said:
Yeah I've had that recently too on a hotpoint washer, they seem a bit too much of a tight fit, in the past they used to just pop out.
Strange isn’t it . Washer will be lucky to last 3 years in its environment; the transit fitting could hold the titanic together ( ignoring the hole with water flooding in )
