AliG Posted January 6, 2020 Posted January 6, 2020 Hi, I have noticed quite often that the water from one of our kitchen mixer taps is not hot. I had put it down previously to maybe being a quirk of our circulating hot water system. But I noticed at the weekend that the other tap in the kitchen was hot and this one just lukewarm whilst running them at the same time, so now I realise there is probably an issue with the tap. It is a Blanco Culina S-Mini. The temperature starts cold when set to cold but only moves to maybe 30C when you move it to hot. Looking on line I found a video suggesting that you need to flush the pipes when you install the tap. Could it be that there is dirt in one of the pipes, or could something else be causing this issue? Thanks
Barney12 Posted January 6, 2020 Posted January 6, 2020 Could be crud but equally the cartridge might have failed. No. 5. here. https://blancotapspares.co.uk/blanco-culina-s-mini-chrome.html 1
