sussexlogs Posted October 30, 2016 Posted October 30, 2016 (edited) Edited October 30, 2016 by sussexlogs
DavidFrancis Posted October 30, 2016 Posted October 30, 2016 sussexlogs - I find some of your your posts rather terse, to say the least! Have you been taking lessons from Tony? How big's that cavity? Are you having any insulation? If so, will it be blown in? And why are the lintels on the on the inner skin so much higher than those on the outer, or is that "lintel" over the further opening part of a beam and block floor?
sussexlogs Posted October 30, 2016 Author Posted October 30, 2016 14 minutes ago, DavidFrancis said: sussexlogs - I find some of your your posts rather terse, to say the least! Have you been taking lessons from Tony? How big's that cavity? Are you having any insulation? If so, will it be blown in? And why are the lintels on the on the inner skin so much higher than those on the outer, or is that "lintel" over the further opening part of a beam and block floor? cavity is 170mm. yes blown in .yes part of beam & block 1
