Raks Posted December 4, 2019 Share Posted December 4, 2019 To put a isolation valve over the floor level for a pipe running under, is there any "bottom only connection" type valves? Let me explain what I meant: Right now to add a isolation valve: straight up pipe to floor level + isolation valve + short straight + U bend connection + straight back to the pipe under floor. I just wonder if there are special valves with two connections at the buttom one for IN one for OUT so nice tidy two pipe connection without extra bends and soldering. Link to comment Share on other sites More sharing options...
dpmiller Posted December 4, 2019 Share Posted December 4, 2019 Surestop stopcock under the floor with remote "switch " on the wall above? https://www.screwfix.com/p/surestop-remote-stop-cock-push-fit-15mm/48604 Link to comment Share on other sites More sharing options...
Raks Posted December 4, 2019 Author Share Posted December 4, 2019 14 minutes ago, dpmiller said: Surestop stopcock under the floor with remote "switch " on the wall above? https://www.screwfix.com/p/surestop-remote-stop-cock-push-fit-15mm/48604 this might work for water but I need for gas as well. (but I feel better with a mechanically more reliable lever ball valve) Link to comment Share on other sites More sharing options...
