daiking Posted November 15, 2019 Posted November 15, 2019 I’ve had some osb sheets in my shed for a couple of years. I need something to make some shelves in the loft... Do I run the risk of bringing a garden bug infestation into the house if I use them? should I just buy some clean cheap sheet material instead?
scottishjohn Posted November 15, 2019 Posted November 15, 2019 39 minutes ago, daiking said: I’ve had some osb sheets in my shed for a couple of years. I need something to make some shelves in the loft... Do I run the risk of bringing a garden bug infestation into the house if I use them? should I just buy some clean cheap sheet material instead? its manchester for nairobi , no wood boring bettles in uk and wood worm don,t like osb just dust them off -it will be fine bear in mind OSB is not thick enough to make shelves that will have weight on them,unless you going to have brackets every 12" needs to be 1"thick plank or blockboard 1
daiking Posted November 15, 2019 Author Posted November 15, 2019 17 minutes ago, scottishjohn said: its manchester for nairobi , no wood boring bettles in uk and wood worm don,t like osb just dust them off -it will be fine bear in mind OSB is not thick enough to make shelves that will have weight on them,unless you going to have brackets every 12" needs to be 1"thick plank or blockboard It’s the slugs and spiders I’m worried about.
scottishjohn Posted November 15, 2019 Posted November 15, 2019 3 minutes ago, daiking said: It’s the slugs and spiders I’m worried about. you can see them -so just brush them off
