daz1984 Posted October 20, 2019 Share Posted October 20, 2019 Hi all, Trying to calculate the air change rate, the basic formula I've found on google specifically asks for fresh air flow rate. Is there any assumptions made with this figure? I'm not even sure where to start on calculating an accurate figure. We do have a log burner in the lounge so I assume this would maybe cause some fresh air flow? Bathroom fans? But in terms of quantifying a figure I'm at a loss. For some context I'm trying to calculate what size, roughly, ASHP I would require - i appreciate this has been covered many times. I've found a spreadsheet on here so i'm trying to work through that for predicted heat loss. Apologies if this has been covered elsewhere, maybe I'm searching inaccurately. Cheers Daz Link to comment Share on other sites More sharing options...
SteamyTea Posted October 20, 2019 Share Posted October 20, 2019 (edited) Have you downloaded the Building Regulations. They are worth having a read of. Part F covers ventilation. https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/468871/ADF_LOCKED.pdf Edited October 20, 2019 by SteamyTea Link to comment Share on other sites More sharing options...
Jeremy Harris Posted October 20, 2019 Share Posted October 20, 2019 Also worth reading the compliance guide, as well as Part F, plus the NHBC guidance and, perhaps, also the PassivHaus guidance, as all are useful: NHBC MVHR Commissioning.pdf Passivhaus MVHR Commissioning Requirements V121.pdf domestic_ventilation_compliance_guide_2010_edition.pdf Link to comment Share on other sites More sharing options...
daz1984 Posted October 20, 2019 Author Share Posted October 20, 2019 @SteamyTea @JSHarris thank you! i will do some reading Link to comment Share on other sites More sharing options...
