Onoff Posted October 3, 2016 Posted October 3, 2016 Evening, AutoCAD 2010 running on 32-bit Win 7. As per the attached screen shot the Command Line (dragged centre) is odd. For a start it's now black and just has a flashing cursor in it. As you type the cursor moves but you can's see any text. Not sure what I've done wrong! Any ideas?
gravelld Posted October 3, 2016 Posted October 3, 2016 Any use? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-change-the-command-line-colors-in-AutoCAD.html
Onoff Posted October 3, 2016 Author Posted October 3, 2016 52 minutes ago, gravelld said: Any use? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-change-the-command-line-colors-in-AutoCAD.html Cheers for that, spot on! 1
