My 1930s house was re-rendered in the 1980s and now has some cracks. I tried filling some of the cracks with Polycell Quick Set Cement but the cracks reappeared in the same place some months later.
Can anyone recommend a product which would be better suited to repairing this? I'm wondering if something not cement based which is slightly flexible would be more appropriate.
Thanks
  • 2 weeks later...
Toupret Murex (Toolstation do it, other outlets are also available) works. You will nee to angle grind the crack to make it wider and try and undercut the fissure a bit. The trick is to overfill a bit and feather out over the surface and get as smooth as possible. It sets relatively quickly. I damp sponge over as well. You might have to orbital sand back a tad when it has set, don't leave too long. It will never be perfect but you can get a reasonable finish. I am presuming it is painted render.
