jimbobamboom
Everything posted by jimbobamboom
  1. Thanks. I will do as soon as I can figure out again how to shrink the size of my iphone photos for this forum
  2. Thanks Mark C and apologies for the late acknowledgement. I'd signed up for notifications but didn't get notified of your reply.
  3. Thanks MikeGraham21. Apologies for the late acknowledgement. I'd signed up for notifications but didn't get notified of your reply. There is no lock like that on the windows. Can they be retro-fitted, do you know?
  4. Thanks Mr Punter and apologies for the late acknowledgement. I'd signed up for notifications but didn't get notified of your reply.
  5. Hi there. This is my first post on the buildhub. I'm a halfways capable DIY-er, with more mistakes behind me than successes, but I learn. My current problem is the ventilation of my sons' bedrooms. Do you think you can help please? The window in each room has no trickle vent. Please see the attached photos. I do have a sliding vent above each bedroom into the hall. With 3 boys sharing two rooms, a lot of moisture and smell is generated overnight. I am not keen on leaving the windows open overnight, due to draughts and security. After watching a DIY video explaining how to retro-fit a trickle vent in a DG window, I drilled a pilot hole in one window frame, expecting a short penetration into void space within the frame that could likewise be accessed from the other side. Instead I hit something solid - possibly metal reinforcement within the frame. Anyways it looks like trickle vents are out, unless you can advise on what I might be doing wrong with the window frame, or perhaps suggest another means, e.g. through the brick wall? I'm concerned in any case these vents are passive and largely uncontrollable. They are also subject to clogging and the effects of wind and other weather stuff. Buildhub led me to the idea of PIV. I have plenty accessible space in my loft and easy access to gable ends, but not much money. I suspect they are expensive? I have two bathrooms, a kitchen and a living room, as well as 3 bedrooms to be involved in PIV. Do you think that might be a solution? What are the limitations? Can I DIY the installation? I also read about MVHR. Do you think that could work? Again, I don't have much money, what are the limitations? Can I DIY the installation? I read that this solution is dependent on air tightness levels of 5ach or below (air changes per hour). No idea how I can measure that. Do you know? A few questions here. Apologies. I hope you can provide some good advice that will help me. Ay. James.
  6. Hi there. I've recently bought a 1970s build bungalow. The majority of rooms do not have trickle vents in the double-glazed windows. I've joined this hub to seek some advice and guidance on the best way to ventilate my sons' bedrooms. With doors closed at night, and 3 teenagers sharing two rooms, a lot of moisture (and smell!) is generated and I'd like them to have fresh air circulating in their rooms.
