Raine
Everything posted by Raine
  1. Things were so much easier back in the old days of gas boilers and wet rads. The sparks did the electrics, the plumbers did the heating, and there was a tiny bit of task overlap to wire in the boiler. These days, you could employ separate specialists for solar, roofers (for installing in-roof PV), ASHP, UFH, MVHR, batteries and EV chargers. As well as sparks and plumbers! Not to mention the overlap with main contractor works (I’m planning a single main contractor for superstructure up to watertight shell). The system needs to be designed holistically, and I don’t have the patience this time round to study and do it all myself, so I want someone else to do that. I also have an added factor that I’m also doing major structural changes and refurb to the existing 1930s house on the site, and am considering adding an ASHP with upgraded wet rads. I’ll want the same contractors doing both houses. I don’t have limitless funds so I need to be mindful of keeping costs in check. What do people tend to do for heat & power these days? One-stop-shop or separate contractors? If separate, which contractor would do the overall design? If one-stop-shop, is there anyone you’d specifically recommend (or avoid)?
  2. A little hogmanay amusement! I'm reading through a couple of build specs that I found online, to see if there's anything I want to pinch for my spec, and came across this in one of them, which is clearly an amusing test to see if the contractors actually read the spec, and I thought I'd share it!! "Site Meetings The Architect will hold regular site meetings to review progress and other matters arising from the administration of the contract. Contractor to provide tea in blue china mugs on yellow place mats, accompanied with Scottish shortbread." 🤣 🤣🤣
  3. Thanks @Canski. Did you install wet UFH with the posis? If not, do you have no heating on that floor, or rads / elec mats? Good point on the U values too. Something for me to bear in mind as the design fleshes out and I get SAP calcs done. I have spans of ~6m so solid timber is a no go, I assume.
  4. Resurrecting this thread as I have a similar decision to make. @Canski, did you go for beam & block or posis in the end? Do you have any cost comparison calcs or anything else that may be helpful in making such a decision?
  5. Resurrecting this thread as I have a similar decision to make. @iMCaan, did you decide on MF or battens in the end?
  6. Yes and no!😞 The houses in the road were built in the 1930s, and all look good and solid. However, as you can see from the BGS map, the ground conditions on the site are likely quite different from the rest of the road: The neighbour immediately to the south (which looks like similar ground, according to the BGS map) did a rear extension a couple of years back. I have asked them what foundations they had, but they've not got back to me, and I suspect they won't. It's only single-storey anyway, so won't have anywhere near as much load as my two-storey + rooms in roof. My existing house was built in the 1930s and is good and solid with no sign of movement. Attached to the house is a 1970s two-storey side extension that has a distinct DIY feel about it, which has moved significantly away from the main house (I got a big discount on the agreed purchase price because of this). The exact cause of this movement isn't yet known. Here's where I'm at with that: Previous owners claim this was settlement and hasn't moved for years (they would say that though!). Massive ash tree ~3m from the extension felled when I bought the house last year. Trial pit dug exposing the extension foundations. Bottom of concrete @ 1.2m depth Very large tree roots pushing up against the bottom of the concrete Standing water at 1.4m depth We suspect the extension hasn't been properly tied to the main house, which I am hoping to see when we rake out the crack and get a proper look. I am hoping that the movement will stop now that the tree has been removed, and when the extension gets tied properly into the main house (Helifix). Worst case, the extension needs demolishing and rebuilding. 😞 Hmm, maybe I should get the helifix done now rather than waiting, and see what happens over the next few months? If I get that Helifixed and the foundations are still insufficient, where am I likely to see the issue reappearing? At the helifix location, or cracks elsewhere in the extension?
  7. There is a former underground stream which has now been replaced(?) with a Thames Water storm drain. I don't know how much of the underground stream still remains in the wild, but I was expecting to see water here. I presume that pushes us more towards piles than trenchfill? I guess hard sandstone would give a high SPT number thought, right? But it's a very thin layer (and may not even be present at my site), with stiff sandy clay below, to the bottom of the borehole. I was hoping I could have <2m trenchfill (but I've budgeted for 5m-deep piles) but if the ground is soft down to 2.5m, would that make piles more economical? I heard that anything deeper than 2m generally works out cheaper to have piles than trench?? Would the stiff sandy clay provide sufficient bearing for a pile, or would I need to go deeper and find something even firmer (which would likely be deeper than 10m, based on the local borehole)? Or is it a case of it might be sufficient, subject to calcs? Friction piles would be the thing here, right?? In which case, I presume the amount of friction needed would be based on the weight / load per pile, and that would then inform the required pile depth?
  8. Still pondering this. I know the local borehole that I mention above (85m away) is unlikely to be 100% representative of my ground conditions, but it's the best info I have to work with at this theoretical stage, so I'd like to be able to understand and interpret it. I think it's showing me this - have I understood correctly? § 0.1m topsoil § 1.5m of soft brown grey silty sandy clay (to total depth 1.6m) § 0.9m of soft light grey silty sandy clay with decayed roots (to total depth 2.5m) § 0.3m of soft to firm grey silty sandy clay with decayed roots (to total depth 2.8m) § 1.5m of firm grey silty sandy clay (to total depth 4.3m) § 0.2m of hard sandstone (to total depth 4.5m) § 5.5m of stiff sandy clay (to total depth 10m (bottom of borehole)) Is there anything else noteworthy in that borehole report?
  9. Yes, I will be getting a warranty, but I haven't organised that yet. My previous self-build warranty providers were happy to accept SE foundation designs and BCO sign-off, but I guess not all of them will be. Speaking of which, does NHBC Solo no longer exist?? (I am aware that there are other providers, but that was a big one) Thanks for this info Declan, I didn't know any of that. I just want to find the least-cost route of getting foundations that are good enough, without being over-engineered, and of course the SE and warranty providers both have a vested interest in me taking the opposite route. It's hard to navigate.
  10. Thanks both for the replies. So I get holes dug or bored - then what? FYI, I already had a trial pit dug while I was purchasing the house, at a corner of the existing 1970s extension (the house itself is 1930s). The hole revealed 525mm (7 courses) of below-ground brickwork, on 675mm of concrete. I had a 50mm hand auger done to 3m depth at the same time, which filled with water to about 1.4m depth in the couple of hours that the hole was open. The guy who dug the trial pit kept the soil that you see in the below pic. Should I send that away for analysis? Would that be enough? Trial pit was on the right-hand side of the plot, and my plans also include new foundations about 17m away on the left hand side of the plot. I also have a hole currently open on the other side of the site, which was needed for a soakaway test, but that's only to 500mm depth. I could dig it out further, but again, then what? Photo shows the drier, shallower-depth soil at the bottom of the picture, and the wetter, deeper soil at the top of the picture.
  11. Sorry, should have researched more before posting the above! I found this thread: https://forum.buildhub.org.uk/topic/36759-soil-and-ground-investigation-options, and @OwenF's advice on the BGS maps. As with the OP on that thread, I also didn't know this info was publicly available. Thanks so much for this info!! There were two nearby boreholes, the nearest being ~85m away, and on similar ground by the looks of the map: Looks like alluvium to a depth of 4.3m, then a thin layer of sandstone, then stiff sandy clay, right? Borehole 1 is similar but further away. I'm concerned about ground water, as parts of the back garden get waterlogged after heavy rain, but I'm not sure how to interpret the water data shown in the borehole record? The former underground stream (now converted to Thames Water storm drain) that I mentioned above is located here: Would this type of ground generally require piles, do you think? Or standard trenchfill + beam & block? It’s been a while since my last new builds (2011), and perhaps things have changed since then, but neither of them (both of which were on clay soil) required full Ground Investigation Reports, either for the structural design or for the warranty. In fact, I didn’t even need any geotechnical analysis done – the building inspector just examined the open trenches and asked for us to go down a bit further in one corner. I'm perplexed as to why all the SEs I've spoken to so far seem to be being so very cautious by either saying that I'll need Ground Investigation Reports, or piled foundations, or both. I'm on a tight budget and can't afford to throw money away if it's not necessary. 😞
  12. I've recently had planning granted for a new build + mods to existing house, and am trying to find a structural engineer. Some of them are asking for ground investigations to be completed before they will quote, as this will dictate what type of foundations they need to design, and therefore the amount of work they'll need to do. The geological drift map shows alluvium on one side of the site (underground stream, now converted to Thames Water storm drain) and clay on the other side. I'm now stuck, as I don't know precisely what investigations to commission and how to scope these. What would you guys do? Ask the SEs (who are still at presales stage) to advise? Contact some geotechnical companies and ask them? Something else??
  13. If anyone is in need of a good ecological surveyor in the area between Birmingham, Cotswolds, Milton Keynes, Oxford, Swindon, Worcestershire & Gloucestershire, PM me. I found a good one.
      • 1
      • Like
  14. This is from the doc named "baseline": This is from the doc named "as proposed": I was expecting either one or two TERs (one for 2022 Regs and possibly also one for the Planning requirement of 40% improvement) and one DER. There are two TERs, but the lower figure isn't a 40% improvement on the higher figure, so I don't know what they are. And there are two DERs, and I have no idea why, other than I presume the lower figure is my proposal, as he said it passes. Is it just me, or is this hard / impossible to figure out what's what without being told? I know you all say "forget it and move on", but I'm the type of person who likes to understand things (not every detail, but at least to some extent), and also, I might want to down-spec a bit to save costs in some areas.
  15. All understood, but I need to include the relevant figures in my energy statement, which I can't do if I don't know which is which. Maybe you're right though, and I should stop trying to do it "right" and just cherry-pick the most favourable figures at any point in the design and build process and go with those. In the meantime, I'll look on Google for some beginner's guides to SAP and see what I can find to read in my spare time.
  16. I'm at planning stage. LA planning policy requires new dwellings to "achieve at least a 40% reduction in carbon emissions from a 2013 Building Regulations (or future equivalent legislation *) compliant base case". * I.e. now 2022 regs. I've had my design-stage SAP calcs done but I'm struggling to interpret what I've been sent, and the SAP assessor keeps sending me answers that make no sense to me, so I think I'm fundamentally missing something. I'd be grateful if any of you are able to check and correct my understanding, please: I understand that TER is the figure for a notional regs-compliant building of the same size and type, right? So, as long as I meet or improve on this figure, I comply with the regs, yes? I assume the term "baseline" means the TER?? For the 40% improvement required for planning, I assume I just do TER * 0.6? The SAP assessor has told me which figure is 'the 40% improved figure', but that figure is 65% better than the TER, not 40%, so I can't see how that's right. He replied saying: "The reason we use TER for the baseline is that the baseline assumes a mains gas boiler, in SAP10 you need a lot of solar PV to make the DER compliant which skews the figures. Prior to SAP10 we would have just used the DER from the basline & proposed models as a direct comparison to demonstrate the % reduction. This is not possible in SAP10". I have no idea what he's talking about! Is there an idiot's guide that you can point me towards that will explain this?
  17. Yes, I think that's the same explanation that I read / heard before. The problem with that though is that cavity closers (which need to be a tight fit to prevent cold bridging) seem to be sized to match the insulation batts. So, for a full fill cavity, if I go with 150mm Dritherm or Rockwool Full Fill Cavity Batts, and allow 10mm for insulation expansion, that would be a 160mm cavity, but I can't find any 160mm cavity closers. Plenty at 150mm though. I guess I'll have to spec the cavity at 150mm then, and hope that it doesn't push the blocks out of plumb.
  18. What's the news @Moonshine? Did your 5 boxes arrive yet?
  19. I once read that external brick & block wall cavities need to be 10mm wider than the insulation. I.e. 150mm Dritherm 32 would need a 160mm cavity. I can't find where I read that now. Is that correct, or should I ignore / forget it and go for 150mm cavity?
  20. Yes, fortunately I've already got ahead of that particular potential issue! 😁 Shame the previous owners didn't think to do the same a few decades ago with the massive ash tree that was 2m from the existing extension. 😞
  21. So the only thing I can really do is choose my bat surveyor very carefully. Anyone got any experience / tips in greasing the wheels? That is not really my wheelhouse so I could do with some tips. DM me please!!! What a ridiculous farce it all is!!
  22. I've researched and concluded that beating bat surveys is impossible. What do you guys think? Even the prolific, and very savvy, local high-end housebuilder in my area can't do it. In one of their recent bat surveys, the surveyor saw a single Common Pipistrelle (of which there are 2.5m in UK apparently, so not exactly endangered!) popping in to a gap under a roof tile for half an hour on a summer evening, and then leaving. On that basis, the developer had to do the whole supervised hand demolition thing, and install bat boxes on the new house. If the council requests a Preliminary Roost Assessment (PRA), you may as well just factor-in at least a couple of £k to your build budget, and a lot of delay to your schedule, and get on with it: PRA survey & report (maybe £400?) If you have even a single thumb-sized gap under a roof tile, or a bit of mortar missing in a roof / chimney mortar bed, they will identify that as a potential roost location, and require a summer dawn + dusk emergence survey (with 3 or 4 surveyors watching the house for 2 or 3 hours dawn & dusk) & report (maybe £1000??) If the emergence surveyors see even a single bat popping in for even a couple of minutes, that's a strike, and you have to do the full supervised hand demolition and bat boxes. I can't see how anyone can mitigate against those factors. 😞
  23. Yes, I am unfortunately well aware of the dire stats for apps being determined within 8wks. My last one took 8.5 months. 😞 Really good link though @Alan Ambrose - I will save this for future reference. Thanks!! Both my previous LPA and my current one are showing about 45% apps determined within 8wks, so I'm not holding out much hope! I watched with great interest Gove's speech on this topic in the autumn - I wonder when, if at all, if will start to have an impact?
  24. Got another mail from the planning dept saying that they have "removed the request for the additional fee", so all sorted. That's four days of stress and worry that I could have done without! Now I just have a further 8wks (minimum) of even more stress and worry about whether the app will actually be granted!! 😨
  25. Thanks @BigBub and @DevilDamo - that matches my understanding. It is within the same red line boundary - currently a single plot on the land reg, and will need to demolish part of the existing house to make way for the new one. All being done in one single application. I'll keep trying then. It is made even harder by the fact that the Planning department's phone lines have been having issues for at least the past 3-4 months - most of the time you get a "number not recognised" message when you call, and they don't seem to be able to dial out when WFH either, so the only available comms are calling the council central call centre and getting them to send a message, or email (not very helpful when they don't properly read the email!!). Hopeless!!! 😞
