Internet Know How
4 Followers
Internet Know How's Achievements
Regular Member
Regular Member (4/5)
14
  1. So you bring in plasterers and pay the labour element at that rate, if I understand correctly? but then you charge the customer more?
  2. Hi All, What would I generally pay per m2 for square rooms and flat ceilings price per m2 labour only for skimming please? Walls already boarded in most places. Also, price per sqm to dot and dab square rooms Liverpool area Thanks C
  3. Ok so here is the final design 4 floors, 5 manifolds. 1 floor has a 12 and 10 port manifold, and the others either a 10 or 12 port manifold. All pipes to have 150mm centres. Going for smart stats that apparently have a couple of years life in them. Maybe I should have gone with the hard wired stats like I did in the current house but anyhow, decided the smart with app control. We will have 2 boilers linked for the entire house
  4. Hi All, I have UFH to install on my new build property, and I wanted to ask how many separate flow and returns are required to each manifold from the boiler. I'd say each to have a dedicated flow/return back to the boiler room, however what are your thoughts to reducing this down to 3 x flow/returns to all 5 manifolds? What are the drawbacks to this? Is it even recommended as it would reduce the heat up time if 2 manifolds are sharing the same flow and return? Will the UFH equipment provider agree/disagree? Setup: lower ground: 1 manifold (12 port) ground floor: 2 monifolds (5 and 10 port) First floor: 1 manifold (12 port) Second floor: 1 manifold (10 port) Thanks C
  5. Yes all rooms will have their own thermostats and this will be zoned so if I want heating on in a bedroom, it would come on in the ensuite too
  6. Hi All, On a property with full floor UFH, would you install towel radiators in the ensuites? Thanks C
  7. Good read that thanks
  8. Well yeah but I mean you can go out there an get a quote off 4 different people for the exact same job and there can be 100% difference in the price. Also people do tend to quote much higher prices if they are quoting against a more expensive property.
  9. Hi All, What the going day rates for plumbers in north west if you are coming in self employed on a job, and do you price a job up based on you day rate x the number of days you think are in the job. Seeing some very different ranges out there for similar jobs. Cheers C
  10. Hi All, Know any good heating and plumbing merchants to the merseyside area? Thanks C
  11. Hi All, What is the general labour only going rate north west uk for felt/batten/slating a roof? I know it depends on how complex it is, but generally speaking looking to understand where you would price, assuming its on a m2 basis. This would be on a roof over 200m2 Thanks C
  12. Yes have warranty provider involved. Still same quality so I dont see why it would matter if this is all internal.
  13. Yes it will be inside and not exposed to UV so should not be an issue. I can always check with building control
  14. underground stuff seems cheaper
  15. Hi All, Any recommendations on bringing toilet and shower waste water to ground level from a basement within residential? Thinking of either saniflow or sump pump installation in basement void below floor. This would be to support a shower room with a toilet, and a separate toilet/sink, Thanks C
