mr rusty
mr rusty's Achievements
Member
Member (3/5)
13
  1. In the past I've carried out minor developments (very small extensions) using building notices and no formal plans, where my builder has done some of the work and I have done the rest. Under the new BSA regime what is the forums thoughts on how BC will treat a building notice without BC plans? Will the interim inspections and sign off be the same? Or is the building notice option going to become obsolete?
  2. I would say with next door's windows on the side, not a chance you'll get PP for a front extension. If that's a habitable room next door, your extension would need to be under a line at 25 degrees from the horizontal from the centre of the window, which it won't be. https://www.sdcc.ie/en/devplan2022/adopted-plan/related-documents/site-layout-planning-for-daylight-and-sunlight-a-guide-to-good-practice.pdf - that's the UK document BTW that an irish council has kindly put online.....
  3. My understanding, FWIW is that PD only applied to domestic curtilage - I had this on a recent PP for a garden room which I knew would be slightly controversial due to a house only 7m the other side of fence. I was saying to them, "if I can't build this, I'll build this alternative under PD". Planning officer dug out some old google earth pix that showed the garden as scrub and tried to suggest it wasn't domestic therefore no PD anyway. Fortunately I had older photos showing a neat garden, so that argument failed. They allowed the PP for a pitched roof building which had a 2.3m eaves 1m from fence instead of a 2.5m wall at the boundary which was my fall-back 🙂 Point being from this I understand if it isn't domestic curtilage there is no PD. Perhaps investigate what you are allowed to build as an agricultural building then you can argue both ways if you have to.
  4. cynical me thinks they are going to refuse on thin grounds and are trying to stop you going straight to appeal.... Why withdraw it otherwise?
  5. I suspect if it's been going on for 10 years you are out of time to go after the original seller for misrepresentation - I believe the limit is 6 years from the original transaction.
  6. They won't be building over a lateral drain. It's a lateral only as far as your boundary. On their side it's a private drain and they can do what they like (within the bounds of normal building regs). They don't need a buildover agreement and utility company don't need to be involved.
  7. You say tiered your garden. If the other end of whatever you have built is less than 300mm above the original ground level, it might all be permitted development anyway. For example, a deck that starts off 200mm above the natural ground level adjacent, and ends up 1m high as the ground slopes away is still PD. Have a read of this thread and see if it applies to you. Councils have been known to get it wrong interpret the rules incorrectly...https://www.diynot.com/diy/threads/garden-decking-height.491731/
  8. You are tangling PWA with a boundary dispute. IMO the PWA has nothing to do with boundaries, and I doubt there is anything actionable under the PWA legislation. A boundary dispute has its own issues and remedies, and I suggest you will get better/different advice on a forum specialising in boundary disputes and the legalities around them. Remember, that land registry title plans only show general boundaries. Unless a boundary has been specifically determined, your opinion of exactly where it is has no less or more value that your neighbours opinion. If you are in dispute, you will have to go legal, and that is potentially expensive. There is a forum here with some knowledgeable people in it https://www.gardenlaw.co.uk/phpBB2/viewforum.php?f=4&sid=8029c435aa1bd42d74d8410e59f4916e
  9. I'm a DIY builder, but in the day job I work with construction contracts for MEP packages with the tier 1 contractors. The question I always ask when looking at any contract is "who has design responsibility". Most disputes and problems are associated with design, so making sure you understand exactly where this sits is fundamental in assessing the value for money of any service. The alternative to using your own architect is to employ a builder on a full design and build contract, but of course they will price-in the design risk. I'm not going to comment on your post in detail, as this is not what I have experience with.
  10. Not true. If a son is doing work for his parents, then they can do what they like. Arguably it's not even a commercial arrangement.
  11. My 10c on this, is that if you are owed a reasonable amount of money, and can prove it, use these guys:- https://cobrafinancial.co.uk/ My wife did for a £4.5K debt, and 2 months later they went bust. It was a company, and they sent a couple of guys in uniform with body cams to collect the debt. Having them hanging around the communal reception in the shared office obviously worked....... Winning a court case is only any good if you can collect.
  12. You have absolutely no rights to insist this is done. Few points. 1) The PWA in fact can work against you. A developer, putting in place a PWA, does have to follow the agreed plans BUT, should there be any damage caused by the development, with a PWA in place, YOU would have to prove that in fact the damage was caused by the development - the developer is in a much stronger position. Without a PWA, the boot is on the other foot. If you claimed damage, the developer would have to prove it wasn't because of his work, so in some ways you have more power when the PWA is ignored. from a lawyers website:- "If a neighbour claims that they have suffered damage due to a Building Owners works they will provide evidence of this damage in its current state. Without a Schedule of Condition (usually part of a Party Wall Award) to compare conditions before and after it will be difficult (if not impossible) to identify what damage has been caused by the works. As there has been a breach of statutory duty the claim by the Adjoining Owners will usually be assumed by the Court to be correct unless it can be proved otherwise." 2) You have no power to insist that insurance is in place. If the work is being carried out by the son on behalf of the parents so be it. It is the clients prerogative to insist on insurance if they think it is necessary, but not any third party. Like all claims for damages, if there were to be damage you would have to prove negligence. I'm assuming your property is insured. If there were to be a claim it would most likely be your insurers who would go after the developer IF they thought negligence could be claimed. Absence of insurance is not negligence -it's just a choice. Remember that damage does not automatically prove that work is negligent. To prove negligence, you have to prove that the work has not been done with the skill and care that a professional would be expected to carry out. Despite skill and care, unforeseen things still happen, and that's what insurance is for. Of course, a professional contractor will most likely produce risk assessments and method statements (RAMS) for the work to demonstrate they have considered potential risks. Maybe the Son has considered the risks and documented them. You have no right to ask or see his assessments. 3) I suspect this is the crux of it. You just don't like their build. Be careful, because once you start getting down to trifling issues, there is the principal of de minimis. If you start complaining that the house is 200mm different to the plans, most likely the planning may well agree but that the difference is de minimis and does not warrant enforcement. Every plan I have ever submitted to planning has always had "dimensions are +/- 100mm" written on it, and all have been passed. TBH, I'm not surprised they are not keeping you informed. If I had a neighbour coming across as a bit of a PITA, I wouldn't either.
  13. If you are a real cook, you need a good overhead extractor. Not so good over an island. Try searing off some steaks, or chargrilling aubergine slices on a red hot griddle with an in-worktop downdraft extraction only. You'll have a kitchen full of smoke...
  14. The NHBC guidance says minimum of 100mm beam support https://nhbc-standards.co.uk/6-superstructure-excluding-roofs/6-5-steelwork/6-5-4-installation-and-support/ Apologies to @George - I see this has already been posted......
  15. It depends - not all will want to. In any construction it is essential that the client understands who is carrying the design risk. If you employ a designer and give the builder a set of plans to build to, then it's you carrying the risk. Your builder has no contractual relationship with your designer, so if the design goes wrong because the drawings are incorrect, the builder can wash his hands of liability "your drawings, your design", not my problem", leaving you to take it up with your designer who might say "I don't agree with the builder, nothing wrong with my drawings". It is for this reason that many contracts, certainly in the commercial world, are "design and build". The client produces their specification and technical requirements, but the design and the build is carried out by the builder who directly employs the architects and designers. e.g. from an NEC3 ECC contract (which is the first one that comes to hand on my desk) "The contractor provides the works in accordance with the works information, The contractor designs the parts of the works which the works information states he is to design". From the clients point of view it's a very clean way of working since all the risk is with the builder, but obviously the client has to pay the extra for the risk the builder is taking on.
