cbk
Everything posted by cbk
I’m about to lay external patio with porcelain tiles that is flush level to internal space. There are lots of options for pedestal systems to chose from. Does anybody have any experience of which system is best?
BCO has provided a checklist of paperwork required in order to get a completion certificate and the part J is included . I guess I just complete Appendix A myself and see if that’s OK,
I’m nearly at the end of my buil and this included a DIY install for a wall hung bio ethanol fireplace. But in order to get a Completion certificate I need a Building Regs part J checklist signed by a competent person. Any ideas on how to get a checklist completed and who is supposed to sign it?
I was planning to bury so UV may not be an issue, but not very deep so frost might be an issue. Also not sure which type I have as was left behind by plumbers. Is there an easy way to tell PEX from pert-al-pert pipe? Also can you get pipe fittings to join to MDPE for above ground sections with taps etc,
Hi, I’ve ended up with 3 part coils of UFH pipe and wondered if I could use it instead of MDPE pipe to distribute rainwater from my harvesting tank around the garden.
I tried the MCS guys and it turns out that my installer was not up to date with registration fees at the time of my install so no luck there. DNO has confirmed they will issue me an approval for export connection. So my best option seems to be to sign up to the Octopus list znd hope they invite me to join trial. I get the feeling that MCS are putting pressure on Octopus to shut down the trial.
- 20 replies
- feed in tariff
- octopus outgoing
I’ve been trying to sign up now for several weeks and after initially saying all they needed was the G99 declaration ( which I sent) they now insist on an MCS cert as well. My installer has left the market and can’t issue a certificate so I’m stuck.
- 20 replies
- feed in tariff
- octopus outgoing
That seems to make sense. The original announcement was more marketing than a real commitment to offer a new option to join an export tariff. Seems I will have to find an alternative route to get an MCS or Flexi Orb certificate .
- 20 replies
- feed in tariff
- octopus outgoing
Hi, I have a DIY install for PV that I was happy to use a non MCS accredited installer to save cost as the SEG tariff was so low. However I read in Aug that Octopus Energy were going to offer 15p as a fixed outgoing tariff AND would accept just the EREC G99 declaration, as submitted to the DNO by the installer, to allow you to join up. Ive been trying now for several weeks to actually join up but get rejected and it seems there has been a change of policy at Octopus and only MCS or Flexi Orb certified installs are being accepted. They are suggesting as an alternaitive that I can add my name to a list for a £250 admion fee for future consideration withou any commitment as to when. Has anybody else managed to join an outgoing tariff without MCS certification? Is there a way to get a system retrospecitively certified by an MCS registered installer? Any ideas much appreciated.
- 20 replies
- feed in tariff
- octopus outgoing
Ah good point. Will add Hardie backer on the floor as well.
Thanks for feedback guys. Good to know I've got the LiFePO4 type batteries which seem much safer. Additionally my loft space is a fully insulated warm roof so wont suffer extremes of temperature. But just to be safe I still plan to line roof with fireproof plasterboard or would it be better to use the HardieBacker fireprrof board which would save the need to plaster skim the board.
I've ended up installing my Inverter and batteries in a plant room created in the loft space. This is an insulated space and also includes the MVHR. Batteries are Pylon US5000 and I currently have two but hope to add a further two in the future. I plan to line the walls and roof with fire proof plasterboard and the access door will be FD30. If a fire was to occur this should contain things and the room has a smoke detector fitted, but as the MVHR is in the same space and ductwork is plastic this could easily cause smoke etc. to spread throughopuit the house. Should I aim to enclose the inverter and battery setup somehow to reduce the risk of fire spread? Or would this increase the risk of overheating and create more problems than it solves? Or is it a better optiopn to enclose the MVHR and keep it seperated from the Batteries? Any advice much appreciated.
Hi guys I’ve discovered that dpm layer under slab should have been a Radon barrier and looks like a regular 1200g membrane was used. Trying to figure out best option to resolve and keep BCO happy. UFH and screed have been laid but not yet the finished floor of porcelain tiles. Is there an option to put radon barrier on top of screed and under tiles? I’ve also read that if you have MVHR then this can be sufficient to remove any potential Radon and avoid the need for a Radon barrier under the slab. Any advice appreciated.
I've installed standard door linings to first floor bedrooms and plans are approved without need of fire doors. But new BCO is insisting that because I've put a staircase in to reach the loft space, then this now means all first floor doors opening to stairwell need to be rated FD30. Loft space is a mix of plant room and a gym/kids play room so not classified as habitable space. But BCO is arguing that it could be turned into bedroom space in future and hence I need to comply with regs for haitable space just in case. I'm at first fix stage so linings are in and plasterboard is nearly complete. I can add FD30 doors no problem but is there any way to upgrade the frame? Or must these be replaced? Or can I just argue that approved plans are for non habitable space and any change of use would need to address FD30 requirements in the future? Any ideas welcome.
Ive ended up with surplus EPS insulation - 25mm thick and now need to buy some soundproofing to fill stud work walls and first floor ceiling. Can I use up the EPS as sound proofing layer (even a double layer) instead?
Problems with how to finish reveal with aluclad windows
cbk replied to cbk's topic in Plastering & Rendering
I think it is 5mm for each edge but as supplier has gone bust I can't be sure. Will find out when the fitter starts to install. ✌ Thanks ProDave. Pics look a neat solution and I can see how this avoids the problem. WIll discuss with the renderer to make sure they follow the advice and I make sure they don't use any silicone either. I also have some timber clad walls which can easily follow the same principle. One wall is clad in stone slips which are about 15mm thick and will be pointed up with sand and cement. Will need to find a bead deep enough to cope with the depth.- 7 replies
- silicone render
- window reveal
cbk posted a topic in Plastering & Rendering
I'm about to get windows installed and the fitter has pointed out an issue which I'm not sure how to solve. House is an ICF build (Isotex) so all window reveals have to be covered in something to hide the blocks. External finishes are a mix of render (K-Rend Silicone) Stone Slips and Cedar cladding. Windows are Ratinonel Aluclad and structural openings have been made to the size of the window + 5mm fitting allowance. Original plan was to fit the windows and then render the reveal up to the face of the window for a neat finish. Fitter has pointed out that the Aluclad finish may need to be removed for general maintenance of the window and should not be rendered over. Worse still he has suggested that the render may cause moisture to trap behind the aluminium cladding causing the timber frame to rot! When done right there should be a slight shadow gap around the edge of the window which adds to the modern look. My guess is depth of the reveal will be about 50mm so this is a narrow strip that needs to be covered somehow. Only idea I can think of is to use an aluminium flashing the same colour as the window that will be thin enough to fit under and aorund the window and then use a stop bead to render up to the edge of window opening. All sounds a bit fiddly and might end up looking like a dogs breakfast. Any other ideas would be most welcome.- 7 replies
- silicone render
- window reveal
Can you first fix for A/C just in case it's needed in future?
cbk replied to cbk's topic in Other Heating Systems
Thanks for the feedback guys. I've read mixed reviews for the effectiveness of the FCU type units run form the ASHP and maybe not efective enough if there is an overheating problem. As I'm at the first fix stage and dont yet know if I have a problem or not, I'm just trying to cover the optioins and install something suitable just in case. My experience of ASHP installers is they have very little experience of using the cooling features and generally say it cant be done. So maybe as @Thorfun suggested the best option is to get a full A/C design now and request a split quote for first and second fix. I could then remove UFH for first floor bedrooms and use the A/C for winter top up as well as summer cooling. -
I'm about to start the first fix for plumbing and electrics for new build that is as close to Passiv Haus as I could get it and spent a lot of time trying to design out problems from solar gain - Brise Soleil features included in design etc.. Also spent a lot of time thinking about heating (ASHP) and wiring and tried to future proof things as much as possible so will run miles of cat6 cable just in case. But this latest spell of hot weather has made me realise that overheating could still be a problem and I've not really considered options for active cooling. A/C would be the best option and could be run for free from Solar PV. So, I'm wondering if it is possible to put in some 'standard' A/C pipework for the bedrooms just in case this becomes an issue. I was thinking of a standard split A/C system with a single external unit and 4 internal wall mounted units. Would I need to get a design done to size pipes correctly or are there standard sizes (ideally pre-insulated pipework) that I could put in as a first fix item ready to conect up later if overheating was a problem. Any advice, ideas or suggestions much appericiated.
Is there a device I can add to limit the output to 3.68kw?
Solis is G98 and G99 compliant but not G100 😞
That looks a lot simpler. My set-up is single phase so the limit looks like 16kw but I will check with Western Power. I'm planning to use a Solis RHi-5G Hybrid inverter and and an 8.8 (max)kw PV array plus Pylon US5000 4.8kwh battery. It seems DNO will require me to provide some sort of export limiter to ensure export to grid can not exceed 16A. Any suggestions for simplest way to do this?
AndyMB did you get this sorted? I've just discoiverd I need to complete the G99 forms as well and am just as confused as you were. Any advice or sample form would be really helpful.
For info panels are in roof intgegrated type and the informal approval was for PV only and suject to a G99 approval once system design was complete. Ive only recently considered the option to add batteries so can see this will create more issues. Hence the post on here for some recommendations.
Hi, I'm looking for design guidance and recommendations for best Inverter & storage options for a DIY install as part of a new house build. Im not looking for an MCS FIT approved system but just to get maximum benefit from solar PV at lowest cost and would like the capabilitty to run off battery power during the evening and ideally during a power cut. I have a qulaified electrician ready to connect up the system, but I'm a bit confused by all the options. So far I have purchased 24 x Canadian Solar 370W panels (Model: CS3L-370MS-MC4-F30), which is the maximum I can fit on the south facing roof arranged as a 3x8 array. Roof is being tileds now so need to finalise the design asap to allow panels to be installed. Mains supply is single phase and I have checked with my local network provider that they are OK with me connecting a 9Kw array to the grid. Budget is tight so need the option to add additional batteries at a later stage. Any suggestions on best combo of Hybrid Inverter and storage would be really helpful.
