Miller3857
Personal Information
Location
Wokingham
Miller3857's Achievements
Member (3/5)
2
ProDave you are confusing permitted development rights which you do get when the dwelling is completed, unless of course the council have either restricted or withdrawn them and with what I am quoting - two different things.
You don’t need planning to site a mobile home. Under permitted development it allows the siting of a temporary/moveable structure that is required temporarily in connection with and for the duration of the operations being carried out. We have recently completed a barn conversion where we lived in a mobile home for 15 years on site (I told the wife it would be 3-5 years - but that’s a different story). We wrote to the council telling them of our intentions stating under what legislation, we also registered for council tax with no issues. This legislation does not vary from one authority to another (England) despite what you may have read on this post. My advice is be confident when dealing with the council, the bottom line is the law allows you to do it, the council may not like it but such is life!
Screeding or wall plastering, which first?
Miller3857 replied to epsilonGreedy's topic in Floor Structures
Plaster then screed, that way you get a good edge to skirting board to. -
Salus Auto Balancing Actuators - Problems!.
Miller3857 replied to Miller3857's topic in Underfloor Heating
There is no voltage when it gets stuck, there is no power what’s so ever feeding the actuator at that time, they just default to being open for whatever reason. -
Well, I’ve tied what Nick has suggested by making sure they are not over tight and then ‘reset’ the actuators and, initially they work ok, however, after a period of time (24 hours) some decide to go back to remaining open despite no call for heat. To be honest I’ve given up and asked Wunda to refund my money unless they can provide a definitive answer on why this continues to happen and revert back to ‘normal actuators. It will be interesting to see what they say!’ -
Thanks for this Nick, they are hand tight and I did use the body for a bit of extra tightness , I will loosen them off slightly and see what happens. -
No they don’t. -
We are using Honeywell stats. -
Checking back on previous Salus threads back in Jan 2020 it was discussed at length although there doesn’t seem to be a definitive answer it’s clear I’m not alone with this issue. -
Heatmiser. -
I have recently fitted Salus auto balancing actuators to our underfloor system and am having no end of problems with some of the actuators remaining open even though there is no call for heat from the relevant zone thermostat. I have spoken with Wunda who have advised me to go through the recalibration process three times in succession which I have done numerous times and although this does reset them, after anything from a few hours to a day some of them decide to remain open, it’s not always the same ones and there would appear to be no rhyme or reason as to which one it is. It is only when another zone calls for heat that you can see which actuator has stuck open with the flow meter indicating the actuator is open. On one of the zones there are three actuators and it can be just one that remains open with the other two operating properly. The chap from Wunda did say he couldn’t explain why it happened and that sometimes it could be a reoccurring issue or that resetting would solve it - not particularly helpful. Has anyone else had similar issues? Many thanks, Frustrated from Berkshire!
Good afternoon all , I am looking for advice on remote (preferably wireless but not essential) temperature monitoring on our 750 litre thermal store. Basically I would like to have some sort of simple display in our kitchen showing the tank temperature. I have had a good look on line but am struggling to find something suitable, there must be some way of doing it! Many thanks.
Absolutely no issues with plastering tapered edge boards, I have recently done the same for the same reasons as you = short supply! My Plasterer had no concerns whatsoever!
Looking for guidance with a 750 litre thermal store which has twin tappings for immersion coils, one near the bottom the other half way up. We have 4KW of solar PV so want to make the best use of this. Would it be best to have two separate immersion coils or one? If it's one coil which tapping would be best top or bottom? If two coils are the way to go is it possible to control (automatically) each one separately allowing half the store to heat up before switching to the other (assuming the lower) coil? Any advice would be gratefully received. Thank you in anticipation! Rich
Fixing down a low profile shower tray
Miller3857 replied to Besidethewye's topic in Bathrooms, Ensuites & Wetrooms
Thanks Nick for the advice so far, am I right in assuming then that the whole of the underneath of the shower tray is bedded in adhesive not just the bits that have been machined flat.
